tsturm
Can the Snap be Toggled?
I would like to move objects around on a plan which are not on our grid back to our grid.
I do not like having to cycle through the three Snap types. Is there a way to toggle between the Construction Grid Snap and nothing?
TIA
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
You can set a keyboard shortcut to toggle the grid snaps on and off. Go under Options, Customize, Keyboard shortcuts and under the menu Commands-Options is Grid Snap. Set this to a hot key and the toggle is set.
Hope this is what you were looking for.
tsturm
I did find the place to set a keystroke under Menu Commands for the menu of Options (third item down the list).
How is this any different than the Actions Grid Snap keystroke?
And how can I use the different types of Snaps?
Would it be best to use a key to goggle the snap function and another to rotate around among the three snap settings?
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
