Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Custom Object Elevation
Aaron Angeles
hello i upload an object from sketchup. is there a way to customize its 2d elevation symbol?
2 REPLIES 2
I am assuming the object from Sketchup is actually a 3D model?
If that is the case, then you are not seeing a 2D elevation symbol.
You are seeing a side view of the 3D model (object).
The only way to amend that is to amend the the 3D object, which is probably impossible just by editing the object script - it will be way too complicated.
However, you can convert it into a Morph.
Then you can edit the morph, hiding the triangulation lines between faces if that is your problem.
Then you can re-save the morph as an object.
It still may not be an easy or pleasant task, depending on how complicated your Sketchup object is.
Aaron Angeles
thank you barry
