D/W Labels in Elevations
Brett Brown
Hi, Has anybody seen or confirm an issue i'm having. If I set my elevations to manual rebuild the markers get unchecked in D/W settings box. Hence they disappear from elevations. Change back to Auto rebuild and they turn them selves back on and reappear. I can reproduce just by changing from manual to auto. Is this how the label tool is suspose to work? In AC 11. Thanks
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
It's been a long time since I've used window labels in elevation (none of my current clients do this) but I haven't seen this behavior before. Perhaps it is a bug in 11?
Aussie John
Not supposed to work that way.
Cheers John
[/size]
Brett Brown
Thanks for the replys. It is a bug confirmed by Graphisoft NZ.
