DIMENSIONING
...CAN THE PLASTER OVER THE WINDOW FRAME BE DIMENSIONED?? I WANT TO DIMENSION THE DISTANCE BETWEEN THE CORNER OF A HOUSE AND BETWEEN WINDOWS OPENINGS (LIGT DIMENSIONS NOT MASONRY ONES). I USED COMPOSITE WALL AND PLACED WINDOWS WITH "THE TURN PLASTER" OPTION TURNED ON - WHAT I FIND IMPORTANT FOR MAKING AN CORRECT 3D PLAN. IS THERE MAYBE AN ALTERNATIVE?
THANKS FOR THE ADVICE.
0 Replies 0
