ngoldie
DWG to Mesh
I have been following the following Steps to convert a .dwg of a survey to Mesh:
The procedure to obtain this TXT file was:
1- Open the DWG as an Object
2- Copy the 3D script and Paste it into a simple text editor like Notepad/Textedit
3- Save it as TXT
4- Open the TXT in MS Excel
5- Clean the content in order to obtain separate columns with X,Y,Z values
6- Save it again as (the final)TXT
I am unsure as to which of the 6 columns from the 3D script I converted to TXT are the X,Y,Z values? - see attached.
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
2 Replies 2
David Maudlin
Naomi:
This is an article I wrote about the process: Creating a Mesh from a TXT file. I think the fourth column is optional, so you need at least 3 columns with the X, Y and Z values. In your example you need to remove the columns with the zero values.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
ngoldie
Thanks David!
Archicad 20
