Delete Rail Between Corner Posts
Having trouble with a railing where I want the corner posts separated but do not want the rails to turn the corner between those posts. Is there a way to delete the rails just between corner posts?
Thank you!
Try adjusting the end connection length.
Set the connection to 'Disconnected' and then adjust the length for each side.
It can be a negative figure.
Szabolcs Miko
Or, you could go into Edit mode, select the two segments at the corner and delete the Balusters from the pattern (once you're in Edit mode tight click on Segments and nodes, it will be much more easy to select them).
Szabolcs Mikó
Manager, Customer Support
