Dentil Moldings
I have done a search on here a couple times and havent found anything about dentil moldings. Im sure this has come up for other people, so how do I make it or is there something Im missing? I see the molding in the library, but no dentil. I thought about a complex profile, but don't know how to create the "teeth". Any suggestions out there?
Thanks.
Paul
3 Replies 3
Being a repetitive shape, it can only be created by multiplication or a custom part.
Karl
Thanks Karl,
I had thought that my be the only solution. Will give that a shot.
Thanks again.
Paul
vfrontiers
A quick trip outside the box...
Why not use a RAIL object with only VERTICAL pickets set to your TEETH dimensions...
String this along with your CROWN (type) complex profile...
Just a thought...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
