Dwight
EXPLODE. Crash and burn.
Lads:
I'm adding a bunch of roads to an ArchiTerra site - where the roads are defined by curvy walls [they keep their width...], the walls exploded and the resultant fills used to paint on the site....
This element explode thing isn't working - it takes forever to explode a segment of curved wall. Finally resorted to a DXF export/import to get my fills.
Tried ten times - lot of crashing.
Anyone care to comment??
Dwight Atkinson
15 Replies 15
Thomas Holm
Dwight, this is a useless comment and I should keep shut, do not read on from here: I'd just like to add that I gave up on Architerra last fall. I edit meshes by hand. Takes time, but it works. And i get the results i want. And I'm sorry to occupy your bandwidth with meaningless crap like this!
Dwight
Thanks, but I'm not complaining about ArchiTerra - I'm concernd that I'm doing something wrong exploding ArchiCAD wall elements.
Dwight Atkinson
Ben Odonnell
Dwight,
I tried to do as you have decribed above. I couldn't get ArchiCAD to crash, but I did find that ArchiTerra would not work if I selected all of the fills at once.
It did, how ever work if I selected the fill one at a time.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Thomas Holm
Told you my comment was useless!
Dwight
Dwight Atkinson
Thomas Holm
Hey, Dwight, you've posted exactly 1000 more messages than I. What happened? I guess the automatic forum censorship function simply isn't strict enough! Or Djordje isn't alert enough. Whatever. Something's wrong!
Its all of those
double postings
to get his message accross
