Fills on elipses
Does someone know how to fill an ellipse? If you create one and try to fill you get a circle shaped fill.
Hello Rogelio -
I had never tried that before, I am a novice, but I discovered how to do it. Draw your elipse, select the fill tool, set the fill you want, select the magic wand, select the elipse. The fill will fill the elipse.
Cheers - Chris
Dwight
He means "edge of" the ellipse.
Doing this instead of magicwanding the center of the shape forces the seeker to follow that particular edge.
Dwight Atkinson
