Finding total length of a poly line
Hello all,
Is there a way to list the total length of a poly line? If there is a poly line around a building (for example), I want to find out the perimeter.
I know in Autocad there was the "List" function. Is there a similar feature in Archicad?
A pretty simple command i think. I'm sure there is a way.
Thanks ahead of time!
-Michael
Window > Palettes > Element Information
Thank You. I knew there was a solution!
Thanks
