Floor slab surface area label
When i place a surface area label onto a 100mm thick slab i get the surface area which is exactly what i want.
if the slab is a waflle slab with ribs, the surface area is then incorrect, so i change the layer number on the slab, that works, all good.
But i then use a morpth object that I made to show the rebate edge at the garage door. this also affects the surface area, which i suppose makes sense, but i dont want it to.
I tried changing layer numbers,but it doesn't make any difference.
can anybody make a suggestion, i am now back to using a 2d fill now to get the floor area which i really want to move away from.
Pato99
You can schedule 'gross surface area' also 'gross surface area of the bottom of the slab'. I have also had success creating an additional 1mm material composite on the bottom/top that overrides all other material priorities. It's a pain, but it cannot be seen.
I agree that there should be a 'top surface area to perimeter edge' option Back in the day 'Area' would work just fine.
Maybe someone has a better idea.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Thanks Pat, i have used the bottom of the slab & that works.
