From what I've read here ......
In elevation and section views, the fill patterns that are part of the 3D Vectorial hatching on particular objects can not be adjusted. Would that be correct?
I have created a simple log fill, placed it on a log material and placed the material on a log post object (not an archicad column). So, when I look at this particular post in elevation and sections, so long as those sections and elevations have the 3D Vectorial Hatching option turned on, I see the fill and it is beauftiful...... Except...
If I place 5 posts near each other, the fill is identical on each one of them, unless I move one of them vertically or make the diameter larger/smaller.
In floor plan, the fill is obviously based at a particular origin so when I use that same fill for my purlins, so the fill on each purlin is very different - I like that.
How do I make it work like the floor plan wilst in the elevation/section views?
Aaron Bourgoin
Edit Menu - Align 3D Texture.
Do this in the 3D window.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
