2008-09-23 11:13 PM
2008-10-09 01:20 AM
2008-10-09 12:15 PM
Karl wrote:I'm sure GS CEO knows that spending more money in QA and programmers would fix the problem...
I tend to lean towards Robert's suggestion that GS just has to hire more GDL specialists and to make QA of the library a higher priority. They have to see how that would pay for them, though.
Karl wrote:Personally, I can live without object UI. I'm satisfied with a well structured parameter list. About macros... Why not start scripting/rescripting objects without macros as a standard?... I know the file size would grow (don't know how much)... But it would be much more easy to detect and fix bugs.
If we had every manufacturer producing their own windows/doors (GS and we users tried lobbying for it - and got nowhere)... then users would have a complex mess on their hands if every manufacturer had a different UI and parameter list, and handled common elements (e.g., casing) differently.
Matthew wrote:I agree with Mathew. GS should create and rule an environment for easy object creating with standards and tools. And it could even make money with it...
What is desperately needed is an improved environment/process for creating custom components/parts/assemblies and a clearly delineated set of standards and guidelines for doing this. Ideally the GS parts should set the "gold standard" for properly designed and engineered parts (a "simple title" should not require hundreds of lines of code) and serve as examples to everyone else of how things should be done. This way we would all have a solid base to start from and it would be much easier for everyone to produce consistent libraries of high quality.
2008-10-09 03:24 PM
Braza wrote:Paulo,
2008-10-10 11:49 AM
Olivier wrote:
Doors and Windows make me think to Frankeinstein story.
Olivier wrote:When I talked about scripting without macros, I didn't refer to the core macros like WALLHOLE2...
But your proposition about macros is not realistic. Just for example, WALLHOLE2 tool can work only if it is called by a macro.
Olivier wrote:I'm not saying that external developers have to do GS's job...
Don't count on external developers, it would just add mess to the existing one.
2008-10-10 03:15 PM
2008-10-10 03:45 PM
Olivier wrote:
Paulo,
A more robust library, exempt of bugs should be the first priority.
I second all users pushing in this direction.
2008-10-10 04:42 PM
Braza wrote:Sorry if this statement sounded rude and personal... It was not my intention...
Perhaps I'm being unrealistic... But at least I'm trying to be constructive...
2008-10-14 11:11 AM
Olivier wrote:Ok... Now I'm getting curious...
On June 2007, at Frank Beister and Matthew Lohden's initiative, some folks of this forum
had an interesting exchange with GS team, about GDL improvements.
Without betraying any secret, my feeling is that users can propose, at the end GS decides.
Native english speakers present in this exchange, would explain this better than I could.
2008-10-30 04:30 PM
2008-10-30 05:00 PM
