oliviajane
HELP importing Sketch Up model (from Sketch Up Pro 2021) into Archicad 24
HELP!
I am trying to import a Sketch Up model into Archicad however it does not fully import all of the objects/buildings and I cannot work out why it is doing this. I am importing via File>Interoperability>Merge>Merge from file...
I am working on a MAC PC and running Sketch Up + Archicad on Student licences.
Screenshots attached.
Any help would be gratefully appreciated. Thank you.
Screenshot 2021-11-14 at 20.49.16.pngScreenshot 2021-11-14 at 20.49.50.pngScreenshot 2021-11-14 at 20.45.18.png
4 Replies 4
Hello oliviajane,
Did you try to open your skp file directly by open a new projet into Archicad ?
Is there a difference ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
oliviajane
Hey Chrisophe,
Thanks for your reply.
No, there is no difference. If I directly open the skp file as a a new project, I get the same unfinished model imported.
Hello oliviajane,
Did you try to explode you skp model : no more group or component ?
Christophe - FRANCE
@oliviajane Did you search these forums first for solutions?  It is important to spell things correctly:  SketchUp is one word, not two...
