Help~ problem with setting story level
Hello People,
I have a project which is about 3 buildings situated on an angled ground. (see Attactments - elevation)
My problem is when I use the story level oo to generate the floor plans. I cannot get all the floor plans show up correctly. The building C is hidden and only show building A and B. How can I make building C to show up as well?
The heights and RL levels of building A and C are too different. how can I draw them on the same floor plan and what can I do with Story Level tool? what height of level (building A or C) should I set for each floor level then? If I set building A's story height as 2.700, but becoz of building Cs RL's 2000 higher than building A, plus its floor level height sould be 3.900. (see Attactments - floor plan)
I've been tried to work with story level tool, but I still cannot find the way to draw building on different ground level and different floor height on each level. Please help me! And I'm very appreaciate for your time and advice. Thanks!
"Flat White" wrote:
I think someone has already responded for that ...
but anyhow ... you can consider few things :
- Different settings for some walls ( Cut only , display in home story only ..etc )
- Different views with different cut level ( FPCP )
- overlaying in layout
- different layer combinations ( i don't have a clear vision of that though )
