Hide Transom on floor plan
I have a wall with two windows in it......vertically
I only want the lower one to show on the floor plan
One way to do this or are there multiple ways
David Maudlin
Jon:
You can set the wall to Cut Only, then adjust the Floor Plan Cut Plane for each View so the Cut Plane cuts through the lower window. Walls left on Symbolic Cut will not be affected.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks.
Took your advise and changed signature too.
