AndorSzoke
Hotfix-3 for ArchiCAD 14 (Build 3636)
Dear ArchiCAD-Talkers,
Today we have released Hotfix 3 (Build 3636) for ArchiCAD 14. It is currently available for INT, USA, AUS and GER language versions through the Help menu/Check for Updates... command. Other language versions will follow soon.
Click here for the Release Notes:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC14-3477to3636-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
4 Replies 4
Dennis Lee
Thank you for this, the TW files are working without a glitch updating / referencing each other, much snappier.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
I just installed the update. I have been having problems with the library part editor and was hoping for a fix. Unfortunately the problem persists. (I have reported the bug.)
Otherwise I have had no significant issues with 14.
Hi!
This hotfix, as the previous, is said "all languages". What does that mean? Is it necessary for me to wait for a French one?
JML
AndorSzoke
LUTHRINGER wrote:
Hi!
Dear LUTHRINGER,
The installer application technically works for all languages, nevertheless it is still being tested for several ones. Use the the Help menu/Check for Updates... to know when the FRA language version is available.
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
