Hotspots
I've been using ArchiCAD for some time now, and would regard myself as someone that knows most of the program's features.
But I have never used hotspots, as I don't see the point point of them.
What am I missing here? What do you use them for?
11 Replies 11
tsturm
Daniel states some very good uses for the Hotspots.
I do many of them. I like to set the important ones on a reference points layer and then LOCK it. Then I reset the tool to place them on the ArchiCAD layer.
This way anyone placing them for helpful reminders of center spots or alignments all over the drawing sets can be erased with confidence by shutting off all layers and doing a quick set all and delete.
Once even used them to remember construction grid intersections when the coordinate lines and columns were shut off. Easier to dimension to in this way than a center of a steel column with five hotspots of it's own.
I agree with LINK regarding some of the other tools, however I do see the necessity of the Hotspot tool in the tool palette.
IMHO
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Well.. I was the one who asked the original question. Since then I have started using them with the Patch Tool, which I've recently started to use.
I also see that they could be useful to me if I start making my own GDL objects - which I might as well start doing soon, as I have DaNC here to help!
