IFC tree synch
This message keeps coming up (AC 11) and stops me from doing anything useful for a couple of minutes.
(AC 11 doesn't work hard to get finished with IFC tree synch, CPU = 9.09%)
Is there a way to stop this from happening?
(Normally there is a Cancel button too, but it doesn't work / respond.)
Haakon Alm
ArchiCAD 10 INT (1188) Win XP sp2
ArchiCAD 11 INT (1040) Win XP sp2
Intel Core 2 Duo 6600 / ATI Radeon X1950 / Dual LCD screens HP 30" + Dell 24" LCD
12 Replies 12
RandyC
Same thing happens here but only on certain plans , I haven't figured out why but I remember hearing somewhere that if you adjust the IFC 2x2 or IFC 3x3 then it will syncronize and continue to so for the life of the project, although i cant remember ever touching the IFC menus
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
You mean If I had IFC loaded on my template and remove it from the add-on manager I am with it forever?
I have timed this
Edit a zone -> IFC sync startet (for reasons unknown to me) -> Archicad busy for 4 min 27 seconds
Edit a zone -> IFC sync startet (for reasons unknown to me) -> Archicad busy for 5 min 59 seconds
Edit a slab -> IFC sync startet (for reasons unknown to me) -> Archicad busy for 4 min 04 seconds
This happened 3 times just yesterday.
What a waste of time. Does anybody know how to stop this from happening?
Attached new screen capture, with Cancel button. The cancel button, but not the dialog box, disappears as soon as it is pressed. But the process is not canceled!!!!
was there ever a solution offered for this? we're having the same issue...the biggest thorn in our side is that we're not at a point where we'd take advantage of the IFC component, we're working in AC11 and our consultants are autocad, so we're not even using it (as of now, i know i know, in the future we'll want it)
BUT. for now, its incredibly frustrating to wait on this "update," is there anyway to shut this off, or should we using a different set of objects, etc...??
Dwight
Don't bother with IFC Trees.
They have too many branches.
Use Onyx Trees instead.
Dwight Atkinson
FRUSTRATED.
__archiben
it's very frustrating. if you have any of the IFC panes active in your WE profile, IFC is activated in the file. it means that if just one project of the many you could be working on require some kind of IFC collaboration, all of them get it.
i'm working on a 2x2.66GHz dual core with 5GB RAM and my IFC tree synch takes just under a minute. not as long as you guys, but it's all relative: it's still incredibly frustrating to have to just sit back and watch . . .
~/archiben
b e n _ f r o s t
rjwilden
If you open your Add-on manager and untick the appropriate add-on, this seem to get rid of the problem. Worked for me any how.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
