Import/Export Elevation Markers.
Sadly I forget how to do this but there was a way to import/export items.
And this is the important part - It was from inside archicad when you go say to elevation markers and open up the arrow beside it and it shows you your selections, when you went to the gear there was an option to export/save so you can then bring it into other drawings.
Basically I have messed up shoegnome elevation markers and I need the ones that come with archicad and need them in my template.
And I know this IS possible because I did it about a month ago in an old template and now I completely forget.
Thanks in advance!
1 Reply 1
Well i figured out my own question and who those wondering:
Make item as a favorite - Open favorites palette - Import/export said favorite and repeat to import into new template.
