Internal Cut Error #24
Is it a crunge band...no....a CBGB line up..... no.... or Madonna's new facial procedure...no....it's an internal error message ....this appears after a section is going to be cut...and then it crashes the file.....what I do know....it start occuring after someone used the "Trim To Roof" command on a series of storefront windows and walls....
0 Replies 0
