Modifying Objects on S/E does not take effect?!
When I change a door or window settings in Section or Elevation it does not take effect even with a Rebuilt. Only if I modify them on the plan then modification to settings takes effect, why? Am I missing something?
Thanks,
Joseph
5 Replies 5
Brett Brown
You are not using D/W builder and other Cadimage Tools are you?
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
No,
AC13 D/W Straight Up.
Joseph
Brett Brown
I have,had the same thing but in 3D window, but unload some of cadimage tools seemed to fix it. Perhaps an AC 13 bug then.
Thanks I found the guilty; it is my Cadimage Keynotes!! I unloaded the CadimageTools folder from the Add-On folder of Archicad 13 and now I can modify doors /Windows in Section/Elevation & IE.
I do not want to say any thing bad again about API vs. GDL driven Objects.
I will get in touch with them.
Thanks Again.
They have confirmed the bug and trying to fix it with the help of Graphisoft.
Joseph
