Moving worksheets
Hi!
We are experimenting with using worksheets to place x-ref dwg:s. The idea is to not clutter the plan with often unnecessary linework an to be able to easily rotate and move them.
We use it for example to place a siteplan in our building model and move and rotate it so we can still model close to the origin and orthogonally.
The problem is that every time we open the model file anew the x-ref on the worksheet has reverted to the original place and orientation.
Is this a bug or is there a way to lock it in place?
I should mention we use the worksheet as a Trace on the plan.
Andreas
AC 11 1210 SWE
0 Replies 0
