Need help twisting a wall in OBJECTiVE
I am trying to twist a wall so I can get a nice curved surface between two floors. Using the OBJECTiVE add on, I have been able to twist it; however, as the wall twists, it will need to get 10' longer on the opposite end to connect to the slab below it which sticks out an extra 5' (see image). Does anyone know how I can gradually increase the height and twist the wall at the same time?
Thank you,
Alice
Ralph Wessel
Make the wall depth 25' along the entire length, and then use OBJECTiVE > Tools > Split to cut off the superfluous area.
Ralph Wessel BArch
Central Innovation
