Thea
Need help with Linetypes
Hello,
I have the problem that I cannot change the type of line I am using to draw. All other things can be changed for example the color of the pen etc. I can see all different types for example point lines or the gras line but I cannot pick them.
Can someone here help me?
3 Replies 3
Lee Hankins
Which Archicad version and which computer operating system are you using? There is a known issue with AC26 on macOS Ventura. You can select the livetype by using the arrow keys to move up and down the list of available linetypes.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
ROBBIEB
I have the same issue, using AC26 on macOS Ventura, it's extremely bothersome. Does anyone know when this is going to be fixed? The cursor keys are helpful but not very reliable, it skips line types or just doesn't respond...
Are you running the latest build (5002)?
This was supposed to have been fixed.
DEF-11012 USER INTERFACE: The line types could not be changed in the drop-down menu with the cursor.
