artecon
OPENINGS AND MEP ELEMENTS
I am interested if there is a possibility of connecting the openings in the walls with the MEP elements?
When I set the hole with the tool "create openings with selections", if I move or enlarge the mep element,
the hole will not change and will remain the same dimensions and in the same position.
Is it possible to avoid this problem and if the element is changed
to have the opening automaticly changed as well?
0 Replies 0
