Learn more
Problem with fills
Hi.. Does someone know if this is a bug in archicad or am I missing something? As you may see the color of the fill is not corresponding to the fill's settings .. I have a solid fill with both channels set to white, but after I make the fill, it turns out a bit grey I think I have changed something somewhere but I don't know what. This happened with all the white fills in all my projects. (i haven't noticed any difference with the fills of other colors)
2 Replies 2
try this:
in the fill's dialog box, check what type of fill it is (drafting, cut or cover), then go to Document>Set Model View>Model View Options and to the "Overide Fill Displays" tab to see the options for that type of fill; these are saved with view sets, and you may have inadvertantly saved a view with an overide setting.
David Maudlin
Take a look at Work Environment > User Preference Schemes > On-Screen Options > Automatic Pen Color Visibility Adjustment for Model Views.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
