Profiles are mirrored on the Y axis
I am having trouble placing a simple baseboard profile. Upon completion of the path and saving the part the profile is flipped around the Y axis
1 REPLY 1
DGSketcher
Legend
You might get some help if you explained which version of Archicad you have and possibly supplied some screen images of your setting & what you think is going wrong. The new beam tool in AC23 works different to walls for instance. Without knowing what you are doing it will be difficult to determine if this is a bug or just a setting is wrong.
