Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Project Map or View Map?
I am curious to know. When you start a new project in AC from scratch. Footings on up. Where do you start / draw the majority of your model? Project Map or View Map?
Thanks, Greg
2 REPLIES 2
I ALWAYS use the view map, that way you don't have to constantly adjust layers, model view options, etc.
I only go into the project map when I'm dragging a detail/plan/section over to the view map.
The "model" is in the same place, the view map is just a more organized version of the project map, where you define things like layer combinations, model view options, pen sets, scale, etc. Navigating through the project in the project map, in my opinion, takes longer and is more of a pain in the...
Erika Epstein
Set up some modeling Layer Combinations and include one or more of your dimension layers so you can be checking yourself as you go.
-bldg
-site
-bldg & site
-bldg w/furniture
etc.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
