Project Map to View Map Icons
In the standard ArchiCAD template by default there are Subset Icons relating to certain aspects of documentation i.e Internal elevations, details ect.
If I deleted these, is there any way to get them back?
I have deleted them in a template i'm creating and would like to use them now, however if I drag them from the Project map (which is where they derive from) they turn into a regular folder icon.
4 Replies 4
David Larrew
You deleted a "Clone". You will need to re-Clone the Project Map Folder.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Thanks David - Very helpful
sedley
For interior elevation, it might be better to use the regular folders to organize your save views. By using a clone, all of your interior elevations will be located in one place and the list can get long and becomes hard to navigate.
Using the regular folder will make it easier in that you can make one per room a save the enlarge floor plan area in the same folder.
When you are ready to put the views on sheets you will find things easier.
My 2 cents.
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
Thanks, I agree!
