Section problem
Why is that the beam in a section goes behind the wall? When I make "Bring to front" it always stays behind. Anyone knows why?
Beams have priorities like walls do. Make it higher than the corresponding wall has.
Thomas Holm
"Bring to front" only affects 2D floor plan display, not sections.
Sections are essentially special parallel 3D views rendered with the Internal engine. If the beam is hidden by a wall and you want to see it, place the wall on a hidden layer or make the wall transparent or simply move the wall or beam so the beam can be seen.
