Set up Template
Brett Brown
Hi All, How does one get around the situation where you set up views and layout elevations at zero in your template. Then when you come to do projects, your zero is at say 40 metres, so all your pre set elevations, with 2D stuff already on them, is in middle of screen where you had set them, but the building is at 40 metres and way off screen. Then you have to go through and redo all your preset elevation views and layouts. Hopefully you can tell me the way around this to save all this extra work.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
22 REPLIES 22
Rod Jurich
........ and the screen shot.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Rod Jurich
.......... and one more showing both metric and imperial with a few options.
Rod Jurich
Rod Jurich
..... and now you can d'load from the Depository.
Rod Jurich
