Show line at intersection of two forms
washhh
Hello Everyone,
I'm using AC24 and i would like to see line between tow connected 3d element. For exemple tow wall.
See the image joined
Thank you in advance
4 REPLIES 4
1) In the wall settings dialogue - model panel - override the desired face surface material for the two walls.
2) From options menu - Element Attributes choose Surfaces then duplicate that face material ( only duplication with the same properties).
3) Change the Uncut Line Pen color from Floor plan and Section for only one wall.
hope that helps.
AC 28 INT 3110/WIN 11
Another solution without overriding the surface material is to duplicate ( building material and the related surface ) with the same properties then assign this duplicated building material with duplicated surface to one wall.
Or place each wall into different layer with different intersection level number.
| Archicad 4.55 - 27
I see your solution is effective in plan while mine is effective in 3D, Elev. & Sec. that’s cool, but the question is why and when we need this separator line?
