Trapiziod Window needed
Does AC 8.1 library contain a window object that can have a Raked (or pithed) top & bottom? Like a parallelogram.
Dwight
I think that they all have level sills.
Here is a simple one that does what you need.
Send a private message.
Dwight Atkinson
__archiben
having sat in a DNC workshop last night, i can tell you that WALLHOLE can generate any shaped window/door that you require by reusing 2D polygon data:
david pacifico's tip can be found at
http://www.graphisoft.com/support/archicad/archiguide/customwindows.html
just don't as me to explain it!
~/archiben
b e n _ f r o s t
