Two story walls? Full height or separate?
General question.
If I have a tilt panel wall that is one wall that goes to roof level of a 2 level building. Should I make the wall full height as it should be or do I do a level 1 wall and a level 2 wall of the same properties/attributes?
Reason I ask is if I place a door on the second floor the door is placed on the ground floor if the wall is full height. Then I guess I have to give the floor to floor height on the door settings?
If I make them separate walls for level 1 and 2 it will put it on level 2 without altering the sill height
Which is the correct way to do it?
Thanks
5 Replies 5
You might want to have a look at the window/door anchor.
You can lock the head or sill into the stories as well as the wall base.
Ernest Atanasiu
I suggest you should model 'as built'.
If you want to cut a section showing the wall and floor finishes, it's impossible with one double height wall.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
Agree.
Not sure what you're saying here. (I've never had an issue with sections looking different for stacked vs single walls.)
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Ernest Atanasiu
...then I must be doing something wrong.
in large scale drawings, the priorities of the composites' skins always give me headaches.
I should have said 'more difficult' instead o impossible.
Laura Yanoviak
As a general rule, model as it will be built.
That said, multiple-story elements are an exception, not a rule. Controlling the floor plan view of multiple-story elements can be difficult, and modeling from floor-to-floor is typically the easiest work-around.
