cannot modify roof ridge
Hello.
I built a multi-plane roof, as shown in the image. I would like to move one ridge (as pointed by the arrow), but I cannot, in either 2D or 3D. Does anybody have any idea why this happens and what I can do to solve this?
Thank you.
3 REPLIES 3
I think you will find that is technically not a ridge because the side walls are not parallel to each other.
That is why you can't move it like a ridge with the pet palette options.
You should be able to adjust the pitch of the individual roof planes though and that will adjust the position of your hip.
Like this ...
Hello.
I finally managed. It worked as you said.
Thank you a lot.
