curved stairway
I am just getting started with 3d modelling in archicad 11. I want to make stairs with a curved landing at the top. What is the easiest way to accomplish this? Also, how do I modify windows. I need to draw a casement window that looks like a Koble casement. The casement in the Archicad library looks similar, but I would need to modify the color and a few other things.
7 Replies 7
Thomas Holm
A good idea would be to read about these issues in the Help files and Reference manual.
Erika Epstein
"Location: gold"
Where is this?+
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thomas Holm
Erika wrote:
"Location: gold"
Where is this?+
A nice place to be, apparently. Where you don't have to do any work yourself. Others do it al for you
David Maudlin
Patrick:
I would just use the Slab Tool.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
This might better illustrate my issue. I need to make a metal staircase and I don't want the staircase to have a 90 degree spiral at the top. I don't want it to be a squared off turn at the top of the landing. In this picture, I love the way the staircase at the top looks, but I want it to continue with the same design towards the first floor. I have only been using Archicad for about a month, so it might be something simple I am overlooking.
adzik
Have you tried to use Stairmaker? You can select the "L-Run Winder at Upper End" stair type as a base and configure it to look like the top part of your stair (handrails etc) and then you can fillet its corners to make the turn look like a part from a spiral staircase. Screenshot below.
Running ArchiCAD 23 INT.
adzik
3d view
