Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
cycloid
adbestias
hi!
i work with archicad 11 on windows vista and i need to draw a cycloid; is there a way to do it? is there any generator?
thank you...
13 REPLIES 13
adbestias
thank you all for your time!
i managed to generate a cycloid with CCycloid 3.4.3 (http://www.cgl.uwaterloo.ca/~smann/ccycloid/) and then imported the *.dxf file into archicad; still had to use the spline though.
jean-luc regnier, thank you for the code!
Beart, i couldn't design a barrel vaulted roof with the magic wand; i'll check it out on the manual... thank you!
kliment, thank you too but can you try to mirror your half circle... and notice the difference?
1.Drawing Cycloid:
2.Create a Barrel-Vaulted Roof
Roof Tool > Barrel Vaulted > Click on cycloid by Magic Wand
P.S. Magic Wand : Design > Outline Polygon with Magic Wand (press Space Bar)
Adbestias,
apparently we can approximate a cycloid by a arc of a circle
with Radius of circle = 4 * Radius of the circle which generated your cycloid
if someone wants to demonstrate that...I don't think it is easy
I read somewhere that GalilƩe thought that the cycloid was the best
shape to built a bridge. I am not architect or civil engineer. So may be someone will tell me if it is true just by curiosity...
Best regards
Jean-Luc
