aryastark
how to restrict split's limit ?
valarhi,
check here: https://archicad-talk.graphisoft.com/viewtopic.php?p=319692#p319692
[older version]
i want to cut here with split tool:
https://s12.directupload.net/images/201128/mgy674wg.png
but it cuts also here:
https://s12.directupload.net/images/201128/j4a6aftp.png
i tried marque-ing only where i want it to cut but didn't work.
any suggestion?
[ key: split split tool limit infinite cut limitless cut split tool cuts limitless border extension ]
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
Hmooslechner
2 steps but one:
Go to post
5 Replies 5
Hmooslechner
With the split tool - its limited this way. But as always, there are some other ways:
aryastark
thanks Hmooslechner.
it's not problem with 2D but what about 3D?
actually, while using split tool, it makes us choose a distance. so... what is the point if it will cut infinitely in the end?
why we ara chose distance? it seems an addition a few lines code problem for archicad.
ps:
Ver: AC23
Memory: 16384MB RAM
DGSketcher
Legend
You could always use Subtract from Polygon from the Context menu...
https://helpcenter.graphisoft.com/user-guide/88489/
Either cut a narrow slot and pull the edges back together or duplicate the shape and remove the unwanted part from each version.
Hmooslechner
2 steps but one:
aryastark
thank you much all.
Ver: AC23
Memory: 16384MB RAM
