Jefferson
polyline editing
having trouble unifying large many segmented lines.........could use some help please. Description here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=212144#212144
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
This is a tough. I have not had any problem with the unify command, but I have not used it on massive sets of lines. It also may be a problem if you are trying to unify non-contiguous lines. The other trouble is even once unified they will still have all the original nodes. I'm not sure if there is any easy way to simplify this.
I usually just trace the contours with splines. It's a bit tedious but even complex sites take only a couple of hours, and that way I have complete control of the outcome. They are also much easier to copy and modify for cut, fill, new and alternate conditions.
What happens when you "magic wand" splines on top of the lines?
Richard
AC26 (since AC6.0), Win10
