re aligning cover fill image
bon soiree tout le monde!
A quick question for some work i need to get done tonight, hopefully someone can quickly answer it for me
Ive made a new cover fill image from a photovoltaic jpeg, now when I want to place it ontop of the roof its not aligned to the edge of the roof as I want
Can someone explain how I realign the cover fill so it sits as I need it please
merci
5 Replies 5
(Hope I am not too late - it is already morning here )
In the 3D window with the roof selected, go to Design > Align 3D texture > Set Origin, then pick the point at which your texture should start its repeat pattern.
(Edit - Reading again I see you are talking about a cover fill image, not a material texture, so you must be in either AC12 or 13. This information would have been helpful, add to your signature for future reference. And ignore the advice above, sorry)
Thank you stuart, I have taken your advice and updated my profile.
is there no way to re align cover fills???
Do they not work the same way as vectorial fills, with an option to locate the fill origin? ( I am still on AC11 so don't have image fills, probably the one feature of the latest upgrades I would like to have)
Stuart is correct - yes they do. So, with the roof selected, go to the cover fill options, set the Cover Fill Orientation to Link to Fill Origin and move the handle to where you want the image origin to be.
Thank you ksymons19, ill try that.
