shortcut for snap option
hello,
how could add shortcut for this option I searched and I cant fint any thing,
1 Solution
THANK YOU BARRY , I WILL TRT IT
Go to post
5 Replies 5
I don't see a way to assign shortcuts to each of these individually.
But you can assign a shortcut to "Snap Points Menu" and it will toggle through these options each time you use it.
it works prefectly,unfortunatelyI cant find any place in which I can see what I had choosen .( I mean when I press the shortcut I dont know excaclty what I had choosen )
because of some of them like (best divide and by distance -precent and half ) almost similar in some walls
so, I don`t know if there are any way to see that .
thank you
I always have the 'Control Box' palette active.
I actually use that the set the snap method - rather than a shortcut.
That will change if you do use a shortcut as well.
Thank you barry.
You save me .
