why guidelines don't work when construction snap is active?
2011-09-0909:35 AM
Hi everyone all of us know the importance of grid snap and constructon snap is to establish drawing with accurate predefined outputs in length or width but when this is activated i do not see the guideline is working why i also need guide line in orthognal (perpendicular) lines 90 degree so what shall i do to make grid snap and guide lines working together ?
and thanks
I have been pleased to find that all the snaps and guidelines are working in 15 when the grid snap is on (which was not true before as I recall). What exactly isn't working?
ahmed_hassan wrote: guidelines is not working when gridsnap is active in archicad 15
That makes sense because you are snapping to the grids.
Toggle the grid snap off if you want a random point (guide lines will work while the grid snap is off).
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
