SajW
Pull out properties of multiple selected items in Archicad to Excel
Is it possible to pull out properties of multiple items selected in Archicad to Excel through Grasshopper connection (Basically I need to pull out the element IDs).
2 Replies 2
I suppose so. But why you want to use GH for it. Just do Export directly from Archicad.
Similar if not more complicated request.
Is it possible to pull the ArchiCAD attributes via XML without opening every file and exporting manually?
I'd love to be able to compare the attributes in all of our files vs template files to highlight any anomalies that may be slowing down performance. Worth noting that the majority of our active files are on teamwork.
