2021-03-23
10:37 AM
2023-05-11
11:02 AM
Noemi Balogh
2021-03-23 10:48 AM
2021-05-23 11:13 PM
The first listed skin is consideredhttps://helpcenter.graphisoft.com/user-guide/77393/
•“Outside” when used with Walls
•“Top” for Roof and Slab
•“Reference Side” for Shells.
But the modell does not show up in 2D..Maybe your floor plan cut plane setting is not right, you placed the walls too high/low, floor plan settings of the element are messed up (set to cut only), you have a different layer combination in the floor plan, structural filtering is on and none of the skins are set to be load-bearing, etc... A few things that should be checked.
2021-05-23 11:14 PM
I got it to show up in the 2D in ArchiCAD.Ah, I see. What was the solution for this?
