Multiple parallel inlets for Distribution Boards
Enable multiple inlet connections in DDScad for distribution boards. Support larger high-power systems and parallel inlets for photovoltaic systems. Electrical Power Supply of buildings are a key MEP aspect and there is a wide range of connecting cables to Electrical Distribution Boards.
The more power needs to be provided, the more different methods exist to supply the building and distribute that inside.
That way it is supported to supply one distribution board from several sources, that way several workarounds are eliminated and simplify and speed up the design and documentation process incl. the support of power balance.
Status
Delivered
Last updated: 2024-09-27
Explore the Wishlist
Can't find what you are looking for? Visit the Wishlist to see already collected wishes or Submit your wish
More info
