2007-07-24
07:34 AM
- last edited on
2023-05-30
12:58 PM
by
Rubia Torres
2007-07-24 04:38 PM
scoreville wrote:This is the way to go.
... or will I need an Annotation Layer established for each type of plan that I am noting up in order to not have content from the other plans appear on the wrong layout.
2007-07-24 04:46 PM
2007-07-24 04:49 PM
2007-07-24 04:56 PM
2007-07-24 05:03 PM
2007-07-24 05:06 PM
2007-07-24 05:09 PM
scoreville wrote:NO!... just a detail window or WORKSHEET (new in AC11)...
[Notes Window + Clg Plan Layer Combo = Key Notes for Clg Plan
Notes Window + Floor Plan Layer Combo = Key Notes for Floor Plan]
I see. So would it be best to set up all of those notes on possibly an entire story dedicated to all of these keynotes and then create those view windows in the view map from this story and the necessary individual layer combinations?
2007-07-24 05:14 PM
Eric wrote:With the LAYER COMBO feature... I personally don't see any problem with having a large number of layers... but that's a different debate...
Keep layering as simple as possible!!! Creating too many layers can be a huge management problem. The plan views need the most layer management, as the other views are isolated to the window they are in (i.e. sections, details, worksheets, etc...) Personally, I find it wasteful, even on large projects, to put dimensions, notes, fills, etc. on separate layers if they only show up in the same plan view. You can easily select info by tool or "find and select". Only create separate layers (dimensions,notes, etc.) for the most common plan views when needed. I typically place all 2D info on the ArchiCAD layer that is added to a section, elevation, detail, etc. because they are isolated to their own window anyway, the info is always on no matter which view you just came from, and in Teamwork you can use any layer for 2D embellishing of the isolated windows as long as you include that window in your workspace.
2007-07-24 05:14 PM
Keep layering as simple as possible!!! Creating too many layers can be a huge management problem.I tend to agree and am frightened by the nightmare this could become by creating to many or unnecessary layers within a CAD template. So when it comes to elevations and sections and details you tend to leave all annotation on the ArchiCAD layer because...
