Project data & BIM
Backwards compatability.
This has probably been asked before but is it possible to open R18 drawings (not 3D just simple line drawings) in R12?
If so, how would you do it. I don't really want to save everything as DXF from R18 open in R12 and save as PLN which all I can think of at the moment.
Mark.
6 REPLIES 6
The only other way is if you have the programs for all the versions between 12 & 18.
Save 18 file as version 17.
Open in 17 and save as 16.
Open In 16 and save as 15.
Keep going till you get to 12.
You can only save back one version at a time and you may lose information relating to new features.
Or if it is just the 3D elements you want you could try saving as IFC and then open that in 12 but I can't say I have ever tried that.
Thanks Barry.
I do haveV12, V17 & 18 but want to get the drawings done on V18 to a computer using V12.
Tried saving from V18 as DXF
Opening the DXF in V12 and them saving as PLN but all the line thicknesses go.
Going to try doing same as PDF. ie save from V18 to PDF
open PDF in V12 explode then save as V12 will let you know if it works.
I have moved this post to the 'working in Archicad' section.
The PDF idea didn't work.
I can open the PDF in R12 but cant explode it in the same way you can in V18.
Trying as an IFC file at the moment.
IFC attempt didn't work.
Just going to have to do the work myself.
Could have got it finished by now anyway.
