Changing Attributes in AC 10
Just got AC 10 in the mail the other day and I'm setting up a template for the office that is more streamlined. My question is, how do I modify the fill pattern in the default _2x Wood Frame attribute? I want to duplicate it and change the fill to insulation so it looks more like an exterior wall. Or will it just be easier to duplicate the insulation fill and rename it? If I duplicate the insulation will it screw up any material calculations? Thanks.
pilkovskylm wrote:
...Or will it just be easier to duplicate the insulation fill and rename it?
Yes. Or you can change the fill in the composites.
No. The wall fills are not related to quantity calculations.
