HELP!! Saving in a .DWG formatt from Plotmaker
I cannot express my thanks to you all for your recent help. Last week while fumbling around the lights finally came on and I made leaps and bounds forward, and could not have done it without the help of you all on this forum!
So, now that I have my entire project all layed out in Plotmaker - I LOVE THE PRINT LAYOUT BOOK!! - and have printed a full set of drawing to send to the architect, I now have to send electronic files in .dwg formatt. The User Guide says that I can choose "Save As..." and save drawings in any available drawing or image format. However, the FORMAT pull down menu only displays Plotmaker Layout Book. Why can I not see any other available formats? I need to send these tomorrow or Tuesday morning at the latest. I see where I can save Plotmaker Drawings in any format and that works fine, but can't I save Plotmaker Layouts as .dwg files also?
HELP!!!
As always, I am sure the answer is easy, I just don't know where to find it.
5 Replies 5
Hold the phone - I am reading about Publishing to save Layouts as DXF/DWG files as we speak, or rather as I type! Hopefully I can figure this out tonight, if anyone minds gently nudging me in the right direction, I would appreciate it!
Thanks, all!
I simply having to force myself to think differently than I used to.
Hmmm....Think Different.....where have I heard that before??
The user guide must be out of date. To create .dwg files you need to use publisher under the file menu (similar to AC).
AHH HAAA!!! I found it!! Again, with a few clicks of a button the entire Layout Book is saved in .dwg files! Of course, you all already knew that. Man I love this program! Of course, the Publishing part is not in the Plotmaker section! I haven't used Publisher in AC before, so this is all new to me!
Djorde or another moderator, since I asked a silly question and then opened the manual and 15 minutes later solved my own problem, please feel fee to DELETE this thread!
Of course it is...I can't wait till you discover Plotmaker publishing.
The best is yet to come!
Thanks Richard, I meant in the Plotmaker section of the User Guide. I have it all figured out now, plots wonderfully!
